cracking noise when steering returns from 3/4 position
Guest paulabusa
Guest paulabusa
hi bros, i just gotten my ride last week.
Hope the more experience bros here can help me out a bit.
i realise that when i turn into a corner, there is no sound. but after the corner, when the steering returns to original position, there is a werid cracking sound and cause abit of vibration on the steering wheel.
Any bro encounter this before?
Also, another question, I find that the steering returns very slowly to position, almost most of the time i have to steer back to originial position unlike my japanese rides earlier, i release my steering and it bounces back to position.
Thanks for your help in advance bros. :)
Doesn't sound right. There shouldn't be any sound on the steering column on any turns. Steering wheel should return to straight position on the move by itself, having said that...it depends on the speed of your car when making the turn. The faster the speed, the faster it returns.
i got the same feeling when i first switch over from my latio. the return is quite slow, i think its normal because it sort of give u more control when your speed is low. you will soon get use to it!
Guest hkhamateur
I m w bro Jtang. :becky:
Doesn't sound right! :shocked:
fr peace of mind, bring it dwn to see&see if under warranty n fr warranty purposes. :whistle:
