Transmission position = D
Guest arshavin
Guest Cklasse
Your C180k has a 5spd gearbox, so it should go from 1,2,3,4,D.
This gearbox will drop gears as your speed drops and that's when engine brake comes in. There is simply no fix gear for engine brake, it depends very much on your speed and rpm.
Take for example, I will put to D3 for going down Sheares bridge towards Rochor but put to D1 or D2 when going down Takashimaya carpark. :becky:
