W212 E200 fuel consumption
Guest manu74
Guest chiaster
Another contender for the title of FC King! :lol:
Chia 699 wrote:
W212 E250 with 7G-Tronic, if light-footed, about 8 litre / 100km. Better still, if mum drives, she can reach 6.5 litre / 100km (and she's not road-hogging)
Hahaha! But I think I must be honest now, I live in Choa Chu Kang, and going pretty much anywhere is far from home. I beat the morning rush hour traffic so I don't need to do stop-start, bumper-to-bumper driving, and my family drives to the airport frequently for fun (equivalent to going JB? haha!).
I live on the other side of the island! Haha.
  • Replies 41
Guest Chia 699
Actually I do hit 3000 rpm sometimes, but even then, FC still doesn't increase as much. Highest FC I've got is 9.5 litre / km thereabouts. Do you have heavy objects in your car? You've got a cabriolet right? Shouldn't be much heavier than my sedan eh, plus we've both got the same engine. (Do you have 7G-Tronic? That will definitely affect FC.)
Guest desmondtoo
looks like i've got to learn to be light footed. realise i hit 2500-3000 rpm each time i accelerate. That could be the reason why its hitting 6.5km/l
Not true...I'm also hitting 2500-3000rpm most of the time. Unless you are always heavy footed, else 6.5km/L is quite poor FC.:(
Btw...mine is 5 speed.:)
Guest E250cab
Hi folks... hearing all these..i still find that my FC is high..
Mine is a E250 cabriolet . Its also the 7G tronic rather than the 5 speed.. If that is the case, shouldnt it be more savings on FC??
Desmond, what is your average since u hit 2500-3000rpm most of the time as well..
Guest Chia 699
Dude, what's your cruising rpm? Mine's around 1500-1800rpm at 90km/h with 7th gear. Maybe it's your cruising speed or rpm that causes unusually high FC.
Guest desmondtoo
Averagely I'm doing 8.25km/L.
Guest vincemerz
Actually FC is very hard to compare one.
One can only say if using computer to test 7g FC better than 5g.
But in real life it's quite insignificant anyway.
Comparing FC doesn't work. Same car but sure different driving styles different road conditions.
Different idling times
Different lifestyles.
At the end of the day, most important u happy with your ride.
Comparing cabrio, coupe or sedan still same things = everyone is different.
Guest desmondtoo
Bro, Happy New Year!
The usual you...Cheem!!!:P But agrees with you...most importantly, You're Happy with your ride!!!:)
Guest vincemerz
happy new year!!!
actually want more point to note is FC should be compared with :
1. Same Driver and Between Diff cars that the same driver has driven.
So for my case = Best FC is c class limited edition 5g C180CGI W204, followed by E250 5gCGI cab then E250 7G CGI sedan then 1.8 litre Honda Civic.
Guest desmondtoo
happy new year!!!
So if your above theory is correct, then Cab 5G has better FC than E 7G sedan...:P
Guest vincemerz
Yup u r right.
I don't use eco start stop on my e sedan thou.
happy new year!!!
Guest E250cab
agree with vinmerc.. did realise a great diff between vpower and 98... once u had your vpower once, u tend to compare
anyone had the same observation as per vincmerc and myself... but again,.. fc is going to be high when u accelerate
  • 5 months later...
