Where is the battery compartment for W212
Guest manualisbetter
  • Replies 8
Guest lightning
manualisbetter wrote:
hi, may i ask where is the battery compartment in the car? rear boot or under rear seat? how to access there? thanks.
W212 has only one battery and is located at the rear boot on the driver side...you can see it when you try to access the spare wheel... I was told that jump start can be done from the front engine compartment...
thanks lighting... i tried to look for it in the boot but failed to locate it.. maybe my eyes play trick on me.. will dig deeper again. wanted to check if the battery is still in good condition.. there is no voltage display on our display right?
Guest lightning
chiaster wrote:
gentle reminder to all... it's lightNing NOT lighting!!! please take note! :bounce:
Thanks bro chiaster for highLIGHTING my nick .... :rockon:
I guess most ppl are scare of LIGHTNING...:bounce:
Guest lightning
io5885 wrote:
Bro ur avatar too SMALL, bo power!!
use something BIGGER.. LoLz :laugh:
:Cry: Yalor...somehow this is the biggest avatar I can go...maybe I should change it to my signature instead... :lol:
... never mind call me any type of lights also can... high-beam, low-beam, HID, xenon, LED etc... :becky:
Recently lots of bros address you as LIGHTING ! Actually it's alright ! This also helps to boost your popularity in our club . As most ppl know that the economy in the coming year will be dim . We do need more lightings to brighten the way . So let's bright up ! Hahaha........ :bounce:
