Tayar pressure
Guest vt5sport
vt5sport wrote:
What do u guys pump? Tried 32psi - too soft; 36 - too hard; 34 - juz nice.
i pump different tyre pressure on the front and back.. the inside of the fuel tank lid has the specifications .. and car behaves very well...
Guest vt5sport
chiaster wrote:
i am on 235/35/19... pump 42psi (290kpa) into the tyres everytime i refill the petrol tank... :becky:
wahliew......42psi on 19" :shocked::shocked::hail:
the ride muz be flintstones hard.
Guest hkhamateur
Ai....this's one of the many reasons fr the Best FC obtained! :becky:
Bt 42psi wow....personally felt tat it's too hard and over. :shocked:
Your traction/ grd contact re on min. and pls be v careful during wet condit'n bro!
Chiaster, hve you double cfm the max. psi on your set of tires? Some comes w warning on the tire pressure guide etc...:whistle:
Guest blackknight
i belive i can fly....
Guest chiaster
sure, bro... no problem... :thumb:
Wes23 wrote:
Friday I sit your ride ok? Test test the h&r... :becky:
not exactly, mate... you can take a ride in it too and feel for yourself... but then again, i am used to coilovers on previous cars so i may be used to it... :becky:
bro, actually... during wet conditions, it is better to have higher pressure in the tyres because it "convexes" the ground contact so as to cut through water better... on dry surfaces and for maximum grip, tyre pressure should be lower so that you get more of the rubber's surface in contact... having said that, i have had no problems in the dry or wet with this tyre pressure... :bounce: oh, i am on CSC3 and i remember seeing that the max pressure is something like 50 and up... will go take a look again and let you know, bro... :whistle:
this is bro norman's cue for him to insert the song... :biggrin:
The guru has spoken!!!:bounce:
For a start, u can try 220kpa / 32 PSI for all 4 tires.
then monitor ur handling, cornering, pick up n fuel consumption and adjust from there.
For me, i follow Doc jtang recommendation of +20kpa for rear tires cos of fuel economy n RWD.
i used to be on 225/245 for 225/45/17 BS-050A.
Now on 220/240 for 225/45/17 BS-S001. (harder sidewall)
diff tayar diff spec, diff characteristics.
some harder sidewall, some softer.
some drivers like sharp response, my dad likes soft bounce when over humps.
Play around with d tire pressure to suit your taste. :smile:
Guest mulderang
Thanks Bro will try it when i am free
Guest hkhamateur
io5885 wrote:
No prob, bro.
Rem dat 220kpa is cold tire pressure.
Any issues, just give a shout out.
Many bros here can help. :smile:
Yes bro Ivan, gd point highlighted! Its cold pressure readg! :thumb:
rem guys! Hot air rises n expand! :faint2:
  • 3 months later...
sorry to dig out this old thread but was searching for some anwsers...
After i changed my tires from 17' to 18', i received message saying "check tire pressure".
Is it because is a new set up and the system have not adjust to the new size?
Or what? Anyone encounter this when upgrading your tire? :sick:
U need to reset yr tyres pressure from instrument cluster. Select Service menu & look for Tyre pressure, click YES to reset pressure.
