C200 kompressor Key
Guest Benjamintan30
Guest Benjamintan30
Hi bro and sis here, anyone can help me with this problem. My ignition key holder got a problem now, when I insert the key into the crank start holder, I'm unable to start engine. When to a workshop was quoted 5-6k to replace the key holder. Any recommendation and advices?
  • Replies 6
Welcome!! What's happen to the other key?? Seek second opinion if I were you.
Guest jhun_4040
Yup, do you have a spare key to try ?
Guest hkhamateur
Yo bro Benja, a warm :welcome:
Much earlier I d a similar incident, went dwn C&C Pandan WS to get pb resolve. :hand:
They did a check on my engine program n update it which cost me S$200++ n change batteries fr my two keys! :becky:
It work well since so I see no reason why yr preferred WS diagnose tat e pb re fm yr ignition holder n cost over S$5-6K? :shocked::tsk:
Better find out more! :whistle:
Guest chowellor
hi Benjamin, Just check if your steering locks when you remove the key from the key holder. You should hear an unlocking sound when you insert the key and hear a locking sound when you remove the key. The other method is to check if your steering has free play when removing the key. Keep me posted. Cheers.
