Error message
Guest Zack
Hi guys,
I have a intermittent error message which says "Turn Signal Left Mirror" on my w203.. Any1 have any idea what causes it? SA at c&c say that the signal light might be spoilt but it seems to be working fine..
Few mths back it came on for a few days, disappear for a few days, appear for a few days, disappear for a few days, appear again and disappear since then.. Now came back again and disappeared again..
Thanks in advance!
  • Replies 5
Zack wrote:
Hi guys,
Thanks in advance!
Sounds like loose connection. Did you get it check??
Guest hkhamateur
Zack wrote:
Hi guys,
Thanks in advance!
Morn bro. :hand:
Better fr u to go back C&C n insist tat they do a thru check on yr ride left side light wires n connector! :whistle:
Wires re loose or gotta a cut or overheat due to a small part gotta burn. :shocked:
I'd my experience w my rear left signal till e connector n few wires was badly burnt. :Cry:
Almost e same 'Intermittent' warng sign n tot its e bulbs bt check many times till....it happen. Starblack diagnose n repaired + replaced it. Thankfully! :hand:
Guest Fat Boy
Could be moisture in that part of your car.
In my car I noticed condensation on the inside.
The See & See guy said that side mirror casing has a small crack that allows a small amount of rain in.
Crack could have been due to my carelessness when opening the door, which I doubt, or motor cyclist hitting his handle on the lighting casing or something similar.
Guest chiaster
get it checked, mate... electrical issues can manifest into bigger problems... hope it all turns out well for you... :becky:
Zack wrote:
Hi guys,
Thanks in advance!
