turning off the engine while gear is in neutral
Guest keeptouch
Guest keeptouch
will it cause any damage? somemore my dad tried to use force to remove the key from the ignition when it cannot be removed as the gear is in neutral. he called me for help and i immediately went down to the carpark and realised the gear is in 'N' thats why the key cannot be taken out :mad:
  • Replies 6
Guest Yap ST
Bro can the car be started again after that?
If yes should be ok la.. If NO hmmmm good luck need to sent for repair
Guest keeptouch
the car is fine. its just that my dad turn on and off the engine a few times trying to figure out why the key is stuck without realizing the gear is in neutral.
Guest hkhamateur
Its just a safety feature remindg u to shift back to 'P' when gonna lock yr ride. :becky:
It's e same if auto gear position at 'D' n yr key stack!
Usually there's a warng sound fm e car. :hand:
