W204 Key Battery
Guest Yap ST
lightning wrote:
The ones I bought from supermarket under the Energizer brand is only 3V nia...
Lithium coin typically has low self discharge.
Probably left on the shelves for quite some time!
Occasionally I seen tua lau chwee aka leaking batteries on some supermart displays. :Cry:
Guest lightning
they come in sealed blister pack and show 3V on the pack and on the battery itself leh...:shocked:
Guest nightfly
I think what Unker meant to say was that the actual measured voltage across the +ve and -ve terminals of the cell (using a voltmeter) should read >3.2v when you break it out fresh from the pack. The cell should also be flat and show no sign of bloating. Of course the standard indicated voltage on the packaging is 3v.
Guest lightning
thanks bro for the clarification...:becky:
Bro nightfly is right!
If the battery sitting on the rack for a long time cos boh seng li, due to the cell internal resistance there will be some self discharge.
This will lower the original capacity of the cell.
Though not a direct relation of voltage vs capacity, say the voltage drop to 3.05V. U cannot claim leh cos package label say 3V when typically a fresh cell is >3.2V.
Cum organize visit Unker go eat chili crab & massachi session lah!
Cum late morning & return on the evening ferry.:lol:
