Retrofit side sunblind possible?
Guest Helbreath
Guest Helbreath
Those manual side sunblind for passenger seats, possible to order OEM parts and install?
Hopefully no need change the whole door panel:shocked:
Appreciate all replies here:)
Guest bbwannabe
which model? i have enquired for w211.
iirc you need change the door panel. and, depending on the colour of your door, used parts may come rare!
while you are at it, why not consider retrofitting thermotronic (4-zone air con)? since need to change door panel.
Guest Helbreath
If need to change the entire door panel i think the cost will be quite high. The sunblinds are only a 1,500 option if you spec it.
