Top-up coolant message
Guest MBC200
Guest bossbthk
MBC200 wrote:
Any bros can advise me which type of coolant to use for E-cab? Can I just buy off the shelves and top it up on my own?
Thanks
that fast need to top up coolant ??
i assume radiator coolant
face similar situation b4 ... i top up using distill water cos i was unsure of which coolant to use ... either way ... coolant mostly used to prevent the water frm freezing .. =)
Guest Sanjay
Thanks
use water and monitor... if you see the coolant level low sign again , take it to workshop which will do a pressure test and visual tests to monitor leaks etc... and then take it on from there...
MBC200 wrote:
Thanks all for the advise and will just add water to the radiator..
If you had attend the gtg today you don't even have to add water . Our saliva should be able to cool down your radiator . All mouth open with saliva dripping waiting for someone to bring chocolates . Muahaha....... :pound:
Guest MBC200
Can't make it for the GTG on Sunday cos got to work work work... Maybe i try pouring some Iced Cold Lemon Grass Drinks than it gets more refreshing and cooling....hahaha
Muahahaha........ Bro , keep your homemade delicious lemon grass drink for us on our la kopi 8 lah . Mercedes leh . Although Chinese call 马塞地 , but it's not horse hor . Mercedes don't eat grass hor . Hahaha..... :becky:
Guest Yap ST
Bro yes prepare more of your ice lemon grass for both ur merc and also our La Kopi 8 hahaha
