White Smoke From Car? Brake Pad?
Guest RYANS
Hi everyone!
i'm driving a w204.'07
i experience white smoking coming out from the exhaust :shocked: if i didnt use the car for more den a day. The warming up is little noisy till the smoke lessen.. pls advise?
The brake pad check light came out, so i like to know any recommendation brake pad brands to use???
Good day!
  • Replies 13
Guest hkhamateur
RYANS wrote:
Hi everyone!
Good day!
Bro Ryans, gd day. :becky:
Hve u done anything to yr ride previously? :tsk: White smoke fm exhaust mean there's pb w yr engine, bt am curious why yr engine check lights didn't light-up bt instead fr brake pads? :shocked:
I d experience w my previous ride 'STI'. Workshop checked n found tat e cylinder 4 pressure rate dropped after several test. Spent hell lot to dismantle engine block n discovered e piston ring cracked! :Cry:
My ride has suffered a knock thus white smoke appeared fm exhaust is a symptom of warng. :shocked:
I didnt drive fr days liao n hardly daily used so didnt tot this ll happen on me. Get C&C check if warranty extended or SB or yr frequent workshop to diagnose. Cheers! :whistle:
if its due to piston ring wear off, can i pressume my fuel consumption should be affected? i'm getting 480km-530km full tank. it only happens when i didnt use the car for more den 1day. other den dat its fine. thks for replying
Guest hkhamateur
Subsequent cracked start yr ride, any more white smoke? :whistle:
Bcoz its runs on all 4 cylinders, bt once pressure dropped fm either one u may experience engine vibrate more obvious n engine sound thus louder. It may affect yr FC. :Cry:
Guest subaru67
if ride is under warranty from see n see go book appt now or go to A&e dept of see n see.....
but from yr FC seems normal....
maybe its just a cold start... u see like today rained, tml cold start syre alot of smoke like car in genting... and this shld happen only on yr 1st start of the day.
if every start also got smoke even under hot sun than engine got prob liao:Cry:
it could be a cold start like mentioned by some of you. But the smell of the white smoke is very very poisonous.
Could anyone have recommendation for brands of brake pad?/ cost$? need to replace soon :/
If you see the white smoke in the morning start, it's a healthy engine sign. That's water vapor, not smoke. The smell you get in the morning from the exhaust is becos the cat converter is not warmed up to it's operating temp to trap the the bad gases. Usually it takes 5 mins..
Guest Yap ST
Hi Ryans,
I don't have any recommendation for brands of brake pad but heard from some kaki that there is a type of break pad which is less break dust..
U might wanna to try out..
:whistle::whistle::whistle:
Yap ST wrote:
Hi Ryans,
Can the break pads make the car break dance?:becky::becky:
Guest io5885
Yap ST wrote:
Hi Ryans,
Yap ah yap,
Break liao where got dust???
Buang lah... :lol:
