Grounding
Guest subaru67
  • Replies 24
If the box faulty (inductor), yr battery will drain to zero!! Else, yr audio speaker system will be louder, headlight will be brighter & yr ride will hv more power. I might be wrong!!
Guest Yap ST
Mr Blackmerc,
Do you think is good to install one??
Guest subaru67
i have installed the pivot v-capa. its a stabaliser with voltage meter...
car seems more perky but after observing, our car normal volt reading ranges from 12.5v to a max of 14.1v when i WOT but the reading of 12.5 v is when intial starting of engine.after all warm up liao its ard 13.1v
Guest Yap ST
Bro sorry so is good or no good???
Guest io5885
tink no good cos he used a 'but'...
bro subaru67,
where can buy the capa n wats the dmg like?
tinking of having a gadget to help me read my batt..
Kum sia... :smile:
Guest subaru67
its good,.... but i only shocked to see benz voltage so low 1 ah...
constant moving with some times high rpm, the reading is from 12.5 to 13.6v
while my subaru constant reading is btw 13.6 to 14.1v
Guest subaru67
bro subaru67,
Kum sia... :smile:
its good... imo car very lively after installed hahah
bought for 50 http://www.pivotracing.com/product/VMC
the price of 50 is local seller from car forum. just install into the power hole inside our glove box
now i dunno wanto do grounding at engine bat anot with the Razin
Good product and price. I have pm you for the contact.
Guest Martin
The volt reading is taken from the alternator when the engine is switch on, not on the battery. Why is showing lower voltage compare to your ex-ride could be due to some of the component was drawing high power I guess, i can be wrong. Can also change to bigger alternator like those use by pro ICE.
The voltage stabilizer should be useful, just in case that's a sudden surge or drop in voltage, to protect electronic component. That also depends on the capacitor used. How long it take to charge up and the discharge time. Guess is useful if I hv a expensive ICE system installed.
An alternator will reached it rated capacity output typically at 1500rpm & above!
Eg A 100 amp alternator will churn out only about 60 ampere at engine idling speed of usually around 600 rpm.
A High Output Alternator used in ICE usually reads below 12.5V or lower at typical engine idling speed. It's typically recommended to have an external voltage regulated HO alternator.
Rp 2 worth!
Guest MercZai
i read the whole post but only roughly roughly know what you shi fus are talking about , so overall it is supposingly to show a small improvement if i not wrong without any risk involved? if its the case then we should do a GB on it ? :becky: 50 bucks worth to try it ? :shocked:
