Lowering springs for w212
Guest kai
  • Replies 6
kai wrote:
I saw on MBM that they provide service for lowering springs. What is this "lowering springs"? :confused:
Hi Kai,
they are shorter spring than stock spring so if owners are looking at lowering their ride with a more affordable solution, lowering spring is the way to go................
Lowering spring height is standard unlike coilover.
for coilover it can lower to any height you want plus definitely improve the over-all handling than stock.................................
* and also comfy anot it all depends on owner as this is very personal when comes to comfy..............
cheers
kai wrote:
So do our cars need to have the spring lowered? or is it a defect that needs to be corrected?:Cry:
Kai bro...lowering springs are meant for short drivers having difficulty getting into their cars. Generally, if u r shorter than 1.5m it's good to get lowered springs.:becky::becky::becky:
true, or buy a Mini........
cheers
cheers
:pound::bounce: you 2 are good ! Vincemercz where are you ?
