Disc rotor
Guest Gab
Recently i have change to brand new original disc rotors and brake pads....
however, after a series of braking....I noticed the rotors have a 'wong wong' sound during rolling....it stopped when i tap on the brakes...
Investigate and think it must be the brake calipers still biting on the rotor slightly therefore causing the sound...
Anyone experience this before when changing new rotors?
Any experts can help?:Cry:
  • Replies 3
Many reason!! Workmanship, rotor titled, brake pad not fitted properly etc. Normally what I will do is slam the brakes couple of times REAL HARD then check for any abnormal noise. If yes, send in to the workshop again for medical check-up.
When slamming the brake hard make sure do it in a safe way!!
haha thks for advise boss.
did a series of hard braking but doesnt seem to stop the sound. guess i gotta bring down to another workshop to let them see if they can fixed the problem.
Guest blackknight
can be the handbrake adjustment too tight tooo
