Water Condensation seen on plastic portion of side mirror
Guest StevieG
Guest StevieG
Any bros have this problem and how to resolve it?
Also, my right front parktronics would beep for no reason when i just started to drive off and will only stop after a long while. Reall:frusty:y irritating
  • Replies 7
Guest jtang
I'm confused...you have parktronics sensor on the side mirror??
Guest StevieG
no lah...I have 2 problems :)
1) water condensation on side mirror
2) parktornics keeps sounding off
Guest jtang
Is your ride still under warranty? If it is, the side mirror will be changed with no question asked.
As for the parktronic alarm, switch it off to reset the sensor & then try again.
Do provides yr ride infro.
1) use rainX to clear it. Does yr ride hv heating element for the side mirror too?
2) wire shorted due to sensor stain with dirt or water seepage is likely the problems.
Just send in for medical check up & provides feedback after that.
Guest StevieG
Bro, Mine is a W204.
1) the condensation in beneath the plastic cover. how to know if my ride has side mirror heating element bro?
2) will mostly likely do so in next servicing.
Orh W204 most likely doesn't hv it. Those comes with it usually those higher end model. Not sure whether E class has this feature. One way to check using the basic technique is by touching. Switch on yr heater for couple of minutes then check mirror, if warm means there is a heater. Or look for ask Camber bro to run yr vin code aka birth cert of yr ride whether does it comes with this feature or not.
Do provides feedback of all yr finding!!
Guest StevieG
will definitely do so....
