W211 Vibrating when in D mode
Guest Brian
Guest Brian
Hi all, would like to ask all seniors here as i
just bought a used w211 recently & realise
that whenever the gear is in D mode while
stepping on the brake,can feel the car seems
to vibrate,wondering if its the engine mounting,
anyone experience this before?Thanks & regards.
when braking can feel the vibration? If yes, Is likely the brake mechanism is the caused. The usually suspect is wore out rotor (warp) & brake pad. Do check the caliper sign of crack etc which unlikely. Did ask the dealer when is the last servicing & what's the mileage of yr ride? During test drive u didn't feel the car vibrate when braking?
Orh!! Congras & welcome!!
Guest Tud Tud
high chances is the engine mounting.....
worst scenario could be engine itself running on low air/fuel mixture. idling rpm drop.... try cleaning up the carbon build up within the intake system first.
Guest jtang
I think TS meant the car in D with brakes on.
Guest Brian
yup bro Jtang is right,u can feel the car vibrate when u engage in D
mode,the rpm or idling did not drop,btw any bro know how much the cost
to change the mounting,thanks.
Guest jhun_4040
Brian wrote:
Bro,mai i know how much u paid for it,done at agent?
Nope done at work shop. Look for DarkAv aka Michael. He will quote u a reasonable price !
Guest NewC180
TS, try this:
When you stop at a traffic light, with gearshift in D and stepping on the brake, does the car vibrate?
Next, shift your gear shift to neutral, does the car vibrate lesser or stop vibrating?
If answers to both above questions are yes, then most likely the engine mountings are due for change.
Brian wrote:
Thanks to all for your reply,sent the
Car to C&C and they have confirm it's
I look thru all the posts on this thread and 3 MB doctors were correct with their diagnosis. They are tud tud, jhun_4040 & newc180. :hand::hand::hand:
Guest NewC180
Me no doc, just 'been there done that'! Haha!
Would be interesting to know how much see n see charge for this job. TS please post FR!
Guest Brian
bro yet to send it in for repair cos when i got the
car 2 wks back,the se told me engine mounting just
changed,so now awaiting for him to settle this issue.
Brian wrote:
Sorry all,another quest,is it true the timing belt for w211
is for lifetime meaning don't have to change as its chain one?
Thanks & regards......
Yes is timing chain not belt.
