Break Wear - Visit Workshop W211
Guest jhun_4040
Guest jhun_4040
Does anyone know where a good place and reasonable price to do this fault ? i believe is brake pad ?
I juz did my servicing less then 2 weeks and at that time that particular workshop tell me all is fine when i ask if need to change brake pad anot.
2 weeks later becum like that. i tot perhaps ask around and see if got opinions from other brudders ? Else later bcum Robert get chopped again.
thanks !
Guest Sanjay
thanks !
Hi mate, there are a few things you need to know
1, first and foremost, w211 has a sensor that informs you when brake wear needs attention
2. brake wear can be front or back and mechanic have to check
3. along with brakepads, sometimes need to change discs
i changed mine at hin lung in bukit merah a few weeks ago, but i understand that star black does it at very competitive prices too. They have an ultra clean garage and brake pads matter should be a breeze
4. for the record, i paid about SGD$400 for rear brake pads and discs..
Guest DIY_merc
Sanjay,
your parts are they original merc ?
Guest DIY_merc
Sanjay wrote:
yes they are original merc.. oem ones are much cheaper
How do you know it is original ? Do you go to the workshop to see them change or after changing, you have a way to check ??
I've changed mine recently both front and back including disc and labour >$1k :Cry:
Guest Sanjay
the workshop guy told me they are original parts and i have taken his word for it... btw my price is only for rear discs and rear pads
$400 is a good deal. Does includes labour, gst etc?? Most likely aftermarket or OEM parts but shouldn't hv any concern.
Guest Sanjay
Hi mate, checked with workshop... all original parts.. .. i called again to reconfirm, here is the breakdown rear brake pads SGD$110, rear brake discs, SGD$90 each .. so total SGD$180, rear brake sensor wire, SGD$10, labour, SGD$60 and i changed the gear selector bush at SGD$25... total including labour and tax, SGD$411.95
Good & nice deal. I m sure many bro will pm u :)
Guest DIY_merc
W212
brake pad frt 1x 165
brake pad rr 1 x 150
brake disc frt 2 x 215 = 430
brake disc rr 2 x 130 = 260
brake sensor 2 x 10 = 20
labour 1 x 136
Total 1161
Gst 7% 81.27
Grand total $1242.27
all original merc parts except labour ( local + ft ? ) and gst ( local ) :becky:
DIY_merc wrote:
W212
labour 1 x 136
Total 1161
Gst 7% 81.27
How come u change 1 frt & rear brake pad?
Guest lightning
DIY_merc wrote:
W212
labour 1 x 136
Total 1161
Gst 7% 81.27
pricing seems OK leh...my SA (C&C) told me it may cost 2K plus if I change all the brakes & discs for my w212 :tsk:
Guest DIY_merc
blackmercs wrote:
So u change a pair for both front & rear?
What I was told was that they changed everything brake pads and discs. Don't know how to verify leh but I think most people will just have to trust the company.
Guest DIY_merc
I guess 50% additional profit margin seems right :becky:
Guest lightning
not sure when my brakes are due for change and if I go outside to change...will C&C void my warranty? :confused:
Guest DIY_merc
Check with your buddy SE in C n C. Not sure the computer inside our W212 will know that these have bee changed b 4.
