Sprint booster for sale
Guest FFW211
Guest FFW211
Yes, it will fit in your 2005 W211 E200
Faster Throttle Response
Sprint Booster makes your car's throttle respond faster to your foot. As a result, your gas pedal actually achieves a full throttle response 25% sooner than the stock configuration. Even if you have a 'sport' button, Sprint Booster will quicken the throttle response time. By making the throttle respond faster to your input, you will feel as though your car has more muscle than it really does!
Guest FFW211
• Sprint Booster does not increase Horsepower.
• Sprint Booster does not reduce your 0-100km times.
• Sprint Booster DOES make your car 'FEEL' faster.Sprint Booster modifies the signal between the accelerator pedal module and the electronic throttle body. This modified signal forces the throttle body to open 'more' than the stock signal at a given pedal position. In effect, the idle-to-full-throttle pedal travel is reduced. This makes your car 'feel' more powerful because a given pedal input produces greater throttle opening. This is especially evident in the low to mid rpm range where most cars spend their time on the street.
Sprint Booster simply modifies the throttle signal between the accelerator pedal and the throttle body. Big deal right? Keep in mind, this is the same concept as the 'throttle pulley' modification on cable based throttle systems - which was very popular in it's time. It doesn't add horsepower, but makes the throttle more sensitive and makes the car 'feel' faster.
Guest ACSLK
Andlee wrote:
Thanks for the confirmation. Just as i have always suspected.
Don't think the owner is looking at 0 to 100 performance................is more for better accleration....................too many traffic light in sg thus not much difference at times even if you can cut down 1 sec or 2...............
cheers
Guest Andlee
Hi Alvin, isn't improved 0-100 a quantitive way of measuring improved acceleration? If just base on butt feel, then I guess there is no improvement.
Guest jp168
Bro, pls contact me at 84223781. thanks.
Guest ACSLK
i think is more on the initial launch................like the car is more willing to pull off rather than got to step till quite hard on the pedal...............
cheers
Guest Sanjay
FFW211 wrote:
My sprint booster cannot fit your W209 1.8 kompressor.
any idea how much the garage will charge to install the sprint booster and how long does the installation take?
MBM takes 5 mins!
They used to give "test drive".
Install in <5 mins --> test drive --> Happy Buy not happy take out <5mins.
Guest Sanjay
kepiting1sg wrote:
MBM takes 5 mins!
unker, thanks for the info..any idea how much they charge?
Lost touch - probably $300+ or $400+
Some have fix setting some has variable settings too.
Guest NewC180
Labour charges should be about $20-30. Do it at your regular workshop and they should just charge you a nominal sum. Max 15-30 mins.
