Re-circ issue
Guest scampy
Guest Sanjay
desmondtoo wrote:
Muahahaha...Doc, occupational habit... wearing mask... Hahaha...:lol:
I have read the re-circ matter with much interest. I own a w211 and took it up to port dickson over the good friday weekend... if i click the Auto button, and then press the re-circ button, it will go off after some time... but if i turn on fan speed etc manually, then re-circ stays on or off .. as i desire.. depends whether i want it... just my 2 cents worth
jtang wrote:
Bro, I got a simple solution for all. USE A FACE MASK WHILE DRIVING!
Thanks doc ! Do you have good discount to purchase masks ? Need alot cos passengers also need .
Bro . Read too . There is a way to set as stated but also don't work . Auto or manual also don't work . Cool weather bearable . Today hot , going mad once it starts to re circ within 5-10 mins .
Guest vincemerz
Nowadays I also don't on already. No smell leh....
Just if big lorry then I press...
Bro , you must have got used to it . You had been driving topless right ?
Guest vincemerz
Hahaha no la u mean normal close top also not much smell leh... Same for my c180 cgi actually...
Guest mushigen
Even my newly purchased lao pok W124 is having this issue. Sometimes it lasted 20mins, sometimes shorter.
I thought my previous ride was bad - having to reset it to close each time I start the car. When the ignition was switched on within a certain short interval, the recirculation even stays on.
