w212 light in centre armrest stowage
Guest lalaisgongon
  • Replies 15
lalaisgongon wrote:
hey, bros. those w212s. is there a light in the centre armrest stowage? cause i cant seem to turn mine on?
e coupe / cabrio / sedan & from PI or C&C? Any pics to share?
Guest lalaisgongon
w212 sedan, pi avantgarde. ok later i go take photo. you know the stowage bin behind the gear shift. opens left and right to the side. inside got lamp but no light?
Guest lightning
mine from C&C got light leh...it is turn on as long as the engine is on...
Hi bro . If I'm not wrong , that light only on if your headlights are on .
Guest lightning
if that is the case, I may be wrong...i only notice the light when in the carpark...
Hahaha...., bro lightning . You and I both blur blur . Hahaha.....:becky::becky::bounce:
Wow Sedan is better than E cabrio. When I open up the Armrest box I found a candle & match stick box with a small & fine print say "Courtesy from see & see". No built-in lights!! Didn't know why these stuffs are inside the box till now.
Guest desmondtoo
No bad la...at least something, haha... Mine only got air!!!:caked:
Haha come to think abt it, coupe / cabrio no needs lights for cubby (armrest) box?
You r right . You & bro Des can use daylight in the day & night , moonlight . That's very green for the enviroment . But at those dark multi storey cp then u use ur candle n match sticks given by see & see .
Use matches & candle to check....muahaha!
Since your car still under waranty I guess U should go back to your appointed workshop to check your problems.
Guest lalaisgongon
i more hightech use torch light. hmm yea 2day old only.hmmmm
lalaisgongon wrote:
how bros? i see blub no light? blub blow? fuse blow? how to check?
You mean that light was not on even when engine on and headlights on ? Then better go back to work shop . They will settle for you I'm sure .
