stinky aircon
Guest flairco
Guest flairco
hi when i floor e pedal. around 3000 to 5000 rpm. my aircon produces a stinky smell. like fart. or is it my aircon? not too good when i fetch girls and clients man!
somehow i think i read somewhere in the forum abt the ammonia smell at 3000 rpm. what should i do??
Couple of things u can do, search the forum & read up as this topic is not new. The finding is that missing filter, full blasts yr air con before turn off yr engine & complains to yr SE if still under warranty demand for a thoroughly clean up yr air con system from head to toe.
Guest Luci Ride
Humm, interesting but mine blows garbang smell when one starts car when parked at a hot/exposed place (not all the times it'll blow smelly garbage). Apart from start ups, it ok.
Guest flairco
i tried to search man. got some $388 package by C&C all. but mine aircon is not smelly one. just that hit 4000 rpm and above fart smell comes!
damn! good to know i m not the only one!!
but sai bi upon start up i don't have haha. this one a bit extreme!
yeah happens to me sometimes as well ..
read it could be some dampness inside the air con that may be causing smell ..
i tried to set the air con to blow warm/hot air once a while ( turn AC mode off and max the temp ) seems to resolve issue.
Do you all use air fresheners?
I used to own a Mitsubishi last time, had the sour smell that come from the aircon before. That time, I went to C & C and they told me NOT to use air-fresheners.
Reason being these air fresheners contain Alcohol inside. The alcohol gets into the aircon and will produce the "sour" smell. ( I think when it ferments)
I removed my air-freshener... Remember that time was using ambipur, later, after few days, the sour smell disappeared totally and never came back.
I had the foul smell whenever I start up the car after parking.
I went to C&C and told them the problem..
I don't know what they did.. but the foul smell have gone and it's been 3 plus months..
Guest apple088
I went to C&C to complain. They clean up the Air-con. Was advice not to place the 3M floor mat. The rubber cause the smell. Followed instructions was fine but problem came back again after 3 mths. Smell like moldy towel.
Feel like using mold remover.
Guest Venus
I have exactly the same problem. The moldy towel smell can be quite strong I even need to wind down my windows. It's been like this for a while, and I still haven't figured out what is wrong yet :(
Help pleasee
Guest apple088
Help pleasee
I now throw in a small bag of charcoal under my seat and kept a hippo at the passenger sit. no more smell so far.
Guest NewC180
Help pleasee
I think almost every W204 has this problem. The foul smell is more pronounced especially if you park your car under the hot sun all the time. It seems like C&C can't solve this problem as well. They asked me to pay for the $388 air con cleaning service which I refused, as we had this problem since we first collected the car. Anyway, too tired to quarrel with them over this, and also the smell will go away after a couple of minutes so just live with it.
Charcoal and hippo is good, should help to remove/reduce the smell. Removing 3M floormats is plain BS IMHO.
Guest rmjunior
There are 2 smells being discussed here;
1)Ammonia smell after engine rev are 3 - 5k rpm
2) Mouldy smell
For the Ammonia smell, from my personal experience with B Class (W245). Charcoal / Hippo will not help, it was due to a spare part called "Enhance Flap" (not sure what is it for). After the part changed, still ave the ammonia smell after engine rev, but it was significantly reduced, say 80%
