Basic Knowledges ... Mercedes-Benz E.T.S. (ASR V)
Guest Gan
Basic Knowledge ... Mercedes-Benz E.T.S. (ASR V)
E.T.S. ...... Electronic Traction Susport
here I will like to share with you all ...
about the Mercedes-Benz E.T.S.system
I think is Good For the Benzer to refer ...
the E.T.S. Electronic Traction Susport ...
(some M/Benz Model are equipped with this system)
basically this ETS system ... work as ASR vervion V
The E.T.S. is an automatic system for improving the startup
and the accelaration capabilities particularly on roads with varying traction conditions.
The Spinning of 4 drive wheels is limited or controlled by a brake intervention.
The basic components for ABS and ETS are consolidated in the ETS hydraulic Unit.
The ABS and ETS circuits are also combined in the ETS electronic module
ABS
prevent the wheels from locking up when brakes are applied....
ETS
prevent the driven wheels from spinning when driving off
and accelarating whitin prescribed speed ranges.....
Advantages
. Improved startup and acceleration capabilities resulting
from increased traction on road with vary traction conditions
. Improved stability in curves
. A warning lamp signal when one of the wheel speeds does not coincide with the vehicle speed,
warning the driver that the vehicle is approaching the physical limit for safe driving
hope this helps ....
GONG XI FA CAI .....
