W202 Aircon problem
Guest w202
Hi guys, I'm new to this forum! Hope you can shed some light on a problem with my 1995 C280 (W202).
I've been having problems with my aircon (manual temp. thumbwheels, no climate control). The aircon blower speed switch is no longer working, the fan speed is always either off or very slow, even with the fan speed on 5 and both thumbwheels turned to blue (coldest). I went to a Merc specialist workshop in the West, and they said the aircon panel switch and blower motor sensor need to be changed - parts $1100, labour $500 = $1600! I nearly fainted. :shocked:
I'm considering my options now, which are:
1. Get another quote from aircon specialist
2. Get another quote from another Merc specialist
What do you think? Any recommendations for a good workshop? Thanks for reading!
  • Replies 3
check your pm :becky:
Hi ... understand You Having A Problem On Your Air Con Blower ....
Sound Like The Blower Regulator is Breakdown ....
This Blower Regulator ... eventually was regulate the Voltage Supply To The Blower Motor ...
The Blower Motor Will Running Accordingly to the Voltage Supplied .....
Your Problem ... Seem like the Regulator Does NOT works ....
that was Why The MOTOR ... keep Running at the LOW Speed ...
or A FIX Speed .......
FYI, the Blower Regulator May NOT avialable at the Market ....
You May NEED to be replaced the Whole Complete Set of BLOWER MOTOR .....
If You Need The detail .... Please Provide your Chassis No .....
I may be able to Assist You to check on it .....
Hope this helps ....... :car:
