Greetings from Australia, Sydney.
Guest BenzModz
Guest BenzModz
I would like to introduce myself to the forum. I am on the most serious fans of Mercedes and do all kinds of electrical modifications to my car and others.
I have been invited to this forum by a fellow member and look forward to assisting you with being able to understand what is needed in order to add electrical options to you car.
I have 8 years experience and have done some unusual mods.
Please ask any question and I will do what I can to assist. you will see me assisting in threads. If you want to ask me something please send me a link to the thread so I can follow it.
My email is [email protected]
I am a friend of MBENZNL in the Netherlands whom some of you have bought parts from in the past. I also collaborate with SunMan in Houston whom some of you may remember for putting Keyless Go in his W203.
Apart from that ... anything goes. So long as you use original Mercedes parts you will always be happy.
A warm welcome to the forum Miro! :hand:
Let's see if we can work out some thing for the forumers here who may wanna upgrade their current system to Command.
Guest ivanchan
Hi there,
Warm welcome indeed.......
I have a W221 S350L facelifted and a R171 2008 Pre-facelift SLK200, imported from Japan.
both units were parrellel imported. both units come with GPS, bt only the W221 has it working, as the R171 i cld nt locate the map, despite trying all sources, including KBS, C&C n even the distributor in Japan. haha.
any luck u can come up with the map? or do something? this sounds really dumb as you are based down under, but I was thinking is it possible to use another car map to "duplicate" into my R171?
thks
Ivan
Guest BenzModz
nuoyah wrote:
Hi - is it possible to fit keyless go on an Pre-FL W211?
Yes it is. However it will really hurt your wallet. Think around 10K. This type of job has 3 stages.
a) Buying the parts
B) Installing the parts and coding
c) Waiting for the new keys to arrive from Mercedes.
Would take several days to install.
Guest BenzModz
ivanchan wrote:
Hi there,
thks
Ivan
There are two possible options. The R171 pre-facelift shares the same DVD map as 2006 S-Class and CL-Class. So it would be a matter of installing the correct head unit and the correct navigation DVD drive.
Option 2 is to install an NTG 2.5 and use the NTG 2.5 map. This means throwing out some hardware and installing new wiring but at least it will be compatible with SG.
Guest Cerano
Hi Guys,
I am pleased to announce that from now on, I will address all of your queries and needs for retrofitting of systems on your Mercedes Benz. I will be the sole agent providing these services.
My assurance is that I will be providing the best prices and services of the highest quality and you can rely on me because I am locally based.
Kindly revert to me directly at
[email protected]
or
91525566
regarding any queries that you may have!
If you would like a quote on your vehicle, kindly provide me with your vehicle's VIN
and I will advise you on the available options for your car! The VIN number can be obtained from the driver's door panel or under the windscreen wiper usually.
Zacc
Guest nuoyah
a) Buying the parts
Hi - tks for the advice. It's too much pain for me.
Guest Cklasse5
Zacc,
Since you've been 'appointed' the sole agent on this MB Command APS services, may I suggest that you 'park' an exclusive thread under the trader section so that consumers could easily reference to instead of searching for a couple of threads scattering in a few sections. For your consideration.
My 2 penny feedbacks!
Cheers! :)
Guest Cerano
Cklasse5 wrote:
Zacc,
Cheers! :)
Hi Derrick
Im actually speaking to our mod to see if i can get one such space (:
And i am working with Miro to have a portal up and going for our retrofit systems!
there will be full picture and documentation
Guest ivanchan
Cool info and thks a lot Miro....
Prob is either way I don't noe how to do it....hah. Keep in touch meantime and if there is a chance, wil b great to learn more fm u on the cars.
IVan
Guest BenzModz
IVan
Ivan just lodge your intention with Cerano (Zacc) on the forum here.
Guest Cerano
IVan
ivan feel free to clarify any queries via my phone
91525566 or my email [email protected]
Zacc
