Does the stock c180 come with exhaust chrome tip?
Guest vincemerz
Guest Cerano
im not sure bro
mine the single chrome came stock.
maybe you can go sin ming and check with man exhaust. they are very good.
but logically speaking its just welded over so i dont think its possible that there's noise.
twin small pipes should be brushed metal
exhaust tip should be very cheap 100++++?
plus welding only
Your SE is trying to avoid giving you the chrome tip....
as per my invoice, the cost of the chrome tip is $300+, its not so expensive to ask for... and it certainly is not noisy.
Guest Jupiter
Can get the original Merc tip from Benzline. I did mine for a total damage of $200 w installation. I believe the C200 also having twin pipe if you look inside the chrome tip.
Guest macher82
Hi I also got the tip last year from benzline but is unable to install. May I know where u installed urs?
Guest vincemerz
Huh? Chop off a portion? Sounds scary.... Will void warranty? Scarely didint do well the exhaust knock on the. Grime tip while driing is noisy? Ai,.. Think I don't take the risk... Leave it's raw brushed metal la... Any other way to beautify it safely?
Guest vincemerz
Any bros here on c180 can justify that by installing the oval chrome tip over the two brushed metal pipe will or will not cause the 2 brushed pipe knocking agnst the oval chrome tip while the car vibrates on the road while driving?
Plus where to install better and price?
Or it's just a myth?
What about c200 which comes direct from factory a chrome tip? Any problems?
Guest relagsingh
why dun u ask for the tip from yr SE?
Guest NewC180
My SE did it for my C180, part of the freebies. It was done before I collect my car, and was told that it was done by C&C Pandan. So far no problems at all. A few other bros also did the same thing, no problem at all.
Another BS from your SE I guess...
Guest darkavenger
confirm + chop ur SE is big cannon fairy.
the twin exhaust... they will weld them together.
Guest vincemerz
Haha da pao Xian! I think I agree man... But I think I let go let live Liao la.. If really need do, I go pandanloop c and c myself do la ... Sianz
Guest darkavenger
in case you need a reminder of what the original looks like. HAHAHA
Guest NewC180
That's damn VULGAR!!!
Dark, where you did yours? Share with vincemercz, if not he'll go and do at C&C lio.
Guest darkavenger
wahahahaha. brings home the point to freaking mod the damn tailpipe rite?
mine was my good buddy arrange one leh. workshop is somewhere in Alexander... i really dunno where.... the new tailpipe got from benzline i believe.
Guest NewC180
darkavenger wrote:
oh yah..... today @ raffles place area.... saw a totally stock CLC with the twin straws + stock rims..... reminds me of the "good" old days. haha
Wahahaha! Really 'good' old days man!
Vincemerz, quick go mod your OO into O! It's a must mod thing!
