WTS: Kleeman K-box
Guest pongster
Guest ACSLK
pongster wrote:
Selling my nearly new K-box (W203) due to upgrade. Used only <1000km and already un-installed @MBM. Interested pls PM or msg 81805063. S$2000 o.n.o.
Argh........................wasted i just sold my SLK if not i sure to grab man..........
MTL
Guest pongster
MTL
Alvin, ur Z4 is more chio lor...wahahaha
Guest pongster
As advertised on the front page, the Kleemann Boost Kit pack for the all new Mercedes-Benz C Class W204 w M271 engines is on offer to all members of SGMERC for $3,800.00 INSTALLED.
KLEEMANN has developed an array of power enhancing Engine Performance Kits for Mercedes-Benz cars fitted with a standard OE Kompressor including the AMG models. The simple yet effective design ensures years of reliable performance.
Specific to each Mercedes-Benz model, the KLEEMANN Engine Performance Kit contains a custom-made pulley set, high airflow filters and a K-Box. The pulley is CNC machined and the diameter is increased and precision balanced to ensure a long service life and full vibration dampening. A new belt idler and serpentine belt is also fitted to maintain OE specifications for belt tension and high-flow air filters reduce pressure drops inside the air box to maximize airflow.
The result is greatly improved power and torque throughout the entire engine operating range with crisp throttle response and perfect drivability. Power gains are as much as 20 percent both in horsepower and torque.
KLEEMANN engine Performance Kits are available for the following engines: 1.8 (M271), 2.0 (M111K), 2.3 (M111K), 3.2 (M112K) and 5.5 (M113K).
MBM is selling this kit @$3800 and am only selling at S$2000.
Guest pongster
rssid wrote:
If its the full setup with pullyand so on approx $300++ to install at mbm i think, if its just the kbox should be less
bro, you are right. full setup ard S$350. Am selling the full set :) am overseas from 11th-15th March. Anything juz PM me ok :)
