Changed my W203 to Projector Light with Angel Eyes but light seem not bright enough.
Guest Tommy Tan
Guest Tommy Tan
I had just changed my stocks light to Projector light with angel eyes on my W203. However, the light seem not bright enough even though i changed to a 4300K white hologen bulb. The light also seem to scatter around. Anyway to increase the intensity? or do i need to focus the lens? Any bros kindly advice? Attached is the picture.
Cheerz!
  • Replies 15
Guest Tommy Tan
blackmercs wrote:
Cant see the diff at all, how abt some nite shot pics? I doubt we can be help at all. I believe u r using CCFL not LED?
OK! Will take some nite shots. The angel eyes is CCFL & its bright enough. However, the normal H7, 430K hologen bulb is not bright & not focus too.
Cheerz!
Tommy Tan wrote:
Can i change to aftermrk HID on my normal projector headlight?
Cheerz!
Yes! U can!
"Cheap HIDs" goes <$100
Heard BlackMerc said Philips got offer at $300+
IMHO "cheap HIDs" might have outgassing effect i.e they emit gases during use and in the long term corrode the reflective lining on your
headlamps.
Guest Tommy Tan
kepiting1sg wrote:
Yes! U can!
headlamps.
Hi Bro, care to share where i can get it for <100? As i am using a China made projector lamp, i think a cheap HID will do the job.
Cheerz!
Guest NewC180
Cheerz!
See this thread:
http://www.sgmerc.com/forums/showthread.php?t=10417
Amy's contact: 91933990
Contact bro lightning, he's going to get his HID done with Amy as well. Maybe you guys can go together
NewC180 wrote:
See this thread:
Bro NewC180 is right.
Go contact Bro Lighting.
BTW $130 for H7 HIDs including installation IMHCCBO is a fair price.
Cannot hiam liao!
Easiest get from Amy for <$100 or plus installation for $130
I got my 1st set of foggies from http://www.vvme.com/page.html?chapter=4&id=36 for <$100 shipping included.
I joined another Bro here for GB for my Prado foggies H3 & 9006 also for
<$100 each set.
Tell Amy Yip that Lina Lychee selling for <$100....muahahaha!:becky:
Guest Tommy Tan
Cannot hiam liao!
<$100 each set.
Hi! Bros! Thanks for the recommendation! I was speaking to one seller from ebay & he told me that HID will cause on board error as the normal blub uses abt 55W & HID only abt half the power, thus, the computer will think it is an error. He also said that can be rectify by using a electronics component to rectify the problem. How har? Can Amy recify this problem?
Cheerz!
Cheerz!
NO lah, so many us get it from Amy Yip and ebay no issue at all The ebay guy try to pull a fast one on you. U tell our recommended seller that make sure no error code, if not, get a full refund!!! JUST MOD IT!!!!
Guest arsenal
Please mai confuse Tommy lah, just ask him to call Amy and arrange for the HID test (I mean car xenon lights hor) see whether any error code if yes ask Amy how to remove the error code. If cannot resolve then no deal lor. Ai teh xenons mai?? Blackmercs says one....whahahhaa
Oei, i didnt hor, u mean press left than right is it. If no sound means no error code arh?
Guest NewC180
Cheerz!
Tommy, I'm not sure about your W203, but a lot of bros here with W204 and CLC didn't have this problem. Anyway, Amy is quite a 'steady' supplier, she can do a simple trial on your car and see if there's any error or not. Best thing to do is to talk to her and go to her workshop and let them test. If it works pay for it, if it doesn't work you can just go off without buying. I think she has the error cancellor as well if your car needs it, but will cost extra money lor.
Good luck!
Guest Tommy Tan
Good luck!
Thks for all bros' advices here! I had made a trip to Amy shop yesterday & yes! she is very helpful. However, stocks are not available yet. She said will arrive this week. Will get it fixed once arrived. Hopefully, it will inprove the intensity.
Cheerz!
Cheerz!
I had a W203 & I retrofit with Hella Proector Lamp.
After instal lamp sometime bot working. Went bk workshop & get into the Prog Diagnostic to enable Xenon present.
Nowadays if got problem, most shop & probably @ Amy should have "error cancellor". So have no worries!
I had error on my Audi foggies & cancellors solved the problem ($30).
