AMG Kit
Guest pyro
Hi, newbie here...for AMG kit that PI offer, does it include the sport suspension (its called the advance agility control rite?) If it does, is there a way I can check that it is there? Any button to press? It is not the "S" mode rite? Btw...any good PI to recomend? Thanks.
  • Replies 4
Bro pyro,
Advanced Agility Control is a further option and does not come together with the AMG package. With the AMG only package, you will only get a suspension that is 15mm lower than the standard W204. If you intend to mod the car with Kleeman ECU or change to coilover, forget about the Advance Agility Control function as you modification will render your option useless in the future. Advance Agility is activated through the SPORT button located on the same row as the PARKTRONIC button. With the SPORT button pushed, your dash will show a S as your driving mode. Next to your gear lever is only an M (Manual) button that will be used for manual paddle shift.
I have been running on this SPORT mode occasionally and the car turns into a beast. Revs goes all the way to just before the red line and the pull is exhilarating. Most prominent on stationary stop. Hope my explanation helps.
Yo Bro Lee, thanks for the info! I am confused as the PI told me the AMG package is 16K...blah blah blah...from forum and C&C I know it cost 8k...therefore I questioned him and he told me they got the suspension thingy...So I should just get the AMG package without AAC...any bro knows any reliable PI? I checked with First Automobile...apparently..they do not do indent for C class...
