E200 Keyless-go Systems???
  • Replies 5
Is there one? and how much? if normal remote start one how much?
W211 members?????
anyway your question might be a bit vague. maybe you can rephase your Qs??
are you asking for just the keyless systems? or the price include with the new car purchase??
  • 7 months later...
I have a question on the Keyless go system on my E200.
My front doors are supposed to be able to unlock by just pressing the black square button when teh key is nearby.
However the 2 front doors stopped working 2 days ago.
the back doors still can be opened.
Anyone know what is the problem and if possible where i can repair it?
Olympian
Guest Protoss
Olympian
Pardon me but why do you need to press the button to unlock your car?
Keyless GO should be, pull the handle to unlock and press button to lock car.
Cheers.
Guest four_eggs
hi,
the keyless go system is very sensitive to new wiring if you have installed new audio / video gadget in your merz.
2 weeks ago, i installed a reverse cam and LCD monitor and due to the ground cable of the LCD monitor, the front door keyless button failed. i moved the ground cable to another spot and everything is ok now.
if not, u may hv to go back to C&C. hope this helps. regards, allen
Olympian
Guest dewey
i used to hav the same problem with my old W211, not only unlocking, even when locking, i hav to go to the rear doors to do it... never fix it... i juz change car.
