Gas smell
Clkken
  • Replies 6
Take out the back seat and unscrew both metal cover to check, quite easy
Either the float or filter side is cracked
Happens to mine, parts about $230, I bought from PAS auto
Then you can go to any workshop to replace it, about maybe $100+
Make sure you bought the correct side, best is to take a picture to show the spare part shop
On 19/11/2016 at 0:38 PM, jtang said:
The plastic fuel tank is leaking.....this is a very common problem for W211.
Check by removing the rear seats. Need to replace it bro...
Oh, thanks for your advice. I will try to check on it.
Oh thank you for your advice.
