GB for Racechip Ultimate
lance666
as above min 5
$9XX with installation
sms @ 81982228
http://racechip.com.sg/index.php/chiptuning/mercedes/cla-class/cla-b180-90kw
1.
2.
3.
4.
5.
RACECHIP Ultimate - The Tuning Box that boost the power performance for all Modern Turbo Petrol & Diesel Engine!
UNLEASH THE RESERVED POTENTIAL OF YOUR CAR!!!
*FACTORY WARRANTY REMAINS
*JUST PLUG & PLAY
*Purchase of RaceChip from us and you are able to transfer to your next ride!
*Performance Increase up to 31%
*Torque up to 26%
*Fuel Saving up to 15%
Micro-Controller
Racingly fast performance supply
The intelligent high-end processor ARM Cortex III™ is a micro controller of the Cortex- series made by ARM and is enormously powerful. With its 48 MHz-clocking, it’s the heart of our RaceChip® Ultimate. It needs very little space to provide its very high processing power. The processor only needs microseconds to react on slightest changes in performance.
Glass fibre reinforced Casing
Our heat resistant casing is made of glass fibre reinforced plastic. It perfectly protects all electronic parts of the RaceChip® Ultimate even under adverse conditions. Due to its small dimensions, the RaceChip® Ultimate can be installed easily, quickly and without special tools
The increases in performance (up to 31 %) and torque (up to 26 %) as well as the fuel saving (up to 1 l/100 km) are generally achievable maximum values. They can vary depending on the vehicle.
RaceChip®: Quality Made in Germany
  • Replies 3
If direct Racechip is 1yr warranty.
