Auto stop/start disrupting audio
  • Replies 7
Simplisticnoch,
Wonder whether can install a separate battery for the hifi system, connected n charge togather with existing battery . I believe it can be done, this prevent battery "drain" in high power system.
When yr sound system is off, check the Cap value b4 it turns on again, U'll Know the minimum required voltage.
Try disabled the Eco Start/stop mode, if it doesn't turn off, it mean that yr Cap holding capacity is sufficient to drive yr system.
Frm there, U'll know yr required constant voltage. Conclusion maybe u need bigger capacity Cap.
Very unlikely are the wires or processor problem.
