w212 battery
Tzw
  • Replies 5
Because I got powermagic pro for blackvue. Overnight it cut voltage if below 11.6v monitored quite awhile. Then I go check battery it's actually weak alr
Have you change your battery?
Similar situation with me (but with Urive Albatross2), just afraid that we prematurely change the battery when its not necessary because the system (the car) had no warning signs or prompt to change battery.  Furthermore, i heard that some original merc battery can last much longer like 3-5 yrs (normal usage).
Mine not yet 2 yrs and odo around 20k only.
Btw: C&C battery mark up is too expensive or acceptable?
For your S class I would say it will be not acceptable range.... S class use 100A battery which they easily charge 300++ before labor....Just do it outside..... But my S class battery lasted us for 8years normal usage mileage at 140k then I did change at 180 bucks.
Better to go check battery.
After I spot my original battery dropping below 11.6v after 6mth car cannot start liao hahaha
I change my battery at sinming varta battery also. But agm technology. Full dry cell.
Ace Tyre n Battery..
W212 abt 35 0
At least better than cnc and this ace can ask the uncle help check battery life also
