Audio 10 Ipod connections , can be done?
Guest damienchua
Guest damienchua
Hi bros out there,
I am a new owner of a 2003 c180, took over some time ago . It comes with a Audio 10 system. Like others, I also cannot tarhan burning cds after cds w/o using my ipod. I heard that only Audio 20 system can be upgraded? is it true? i tried the cassette adapter but the cassette was rejected leh... keep ejecting out, dunno what's wrong...
Any advise??
Thankssss
Damien
Guest 777kenny
The current OEM iPod Integration Kit makes use of the Aux-In of the Audio 20 and above. As the Audio 10 doesn't have the Aux-In capability, the kit cannot be used.
One easy method is to buy those FM transmitter for iPod. Alternatively, for maximum quality without replacing the Audio 10, you can consider the Dension 500. See http://www.dension.com/icelinkgateway500.php
Pin Liang in Zion Rd is the dealer in sg. Cost about just short of $1k before installation.
Guest Cklasse
I had read somewhere in other forum that the CD changer can be disabled so that the cable is used for iPod. Another method is to fool the cassette player for ipod use but this involved taking the audio10 apart and do some modification.
Guest damienchua
Thanks for ur suggestion guys.. i'll research n read up on the cd changer trick ..
Wah $1K .. i'll consider seriously, will make a trip to pinliang
Or maybe i can install another Headunit hmm..... damm ICE is so poison.
Guest jenvid
At $1k, you are better off buying a Harmon Kardon Drive+play, throw in a blaupunkt Bremen 74/alpine 9865[i think] head unit + a decent amp + quality speakers. Then do some soundproofing, install acoustics diffuser for speakers[i think that's what they call it], ground cables and you are done. hahaha
