E250 in Sgcarmart
robin1_sg
  • Replies 5
Is it possible to tune to 300bhp using Brabus B25s? Does this vehicle previously belong to anyone here?
This car is already Brabus tuned!
That's my question. Can Brabus tuning achieve 300horses?
I see.
If you did some research on the Brabus website, you will have all the "on paper" data you need. The base car is a W212 pre-facelift E250 with a 1.8L engine producing stock 204Bhp and 310Nm of torque. I wouldn't say it's impossible but it will need some serious tuning to boost the HP output by 100Bhp! Bigger intercoolers, bigger turbos, bigger engine displacement, etc. mainly modifications which are highly frowned upon by LTA.
Brabus has different stage tuning, the base tuning, B25 would produce:
http://www.brabus.com/en/deliver.php?id=6195&filename=W212%20%20B25%20PowerXtra%20CGI.EN.pdf
The more advance B25 S would produce:
http://www.brabus.com/en/deliver.php?id=6199&filename=W212%20%20B25%20S%20PowerXtra%20CGI.EN.pdf
Then again, those are just the "on-paper" data, every engine even the same model performs differently in different environments. You should enquire with the agent and ask for a dyno report to prove the validity of their claim.
