Car key locked in Boot
thaiedwin
help needed my car is stucked in JB legoland and my key in e car boot....unable to open the car....now what can be done?
  • Replies 9
Anyone can confirm does this works?
Usually you have to take the car to MB or call roadside. This procedure (according to roadside from Alexandria Mercedes) is NOT free. It cost me. Anyhow- I watched the tech and this is what he did below:
Just get the doors open then open the fuse console that is along the drivers door on the outside of your dashboard- the door closes on it. Pull out the 4 fuses on the left (7.5 and 5 amps) and then wait a few secs- put them back in and see if the door unlock switch works. If it does- the security system is deactivated and you can use the trunk release to open the trunk. Tech said that if those fuses don't work- pull 4 at a time till you get to the right ones. I tried it in my ml and it worked as well.
Well due to anti theft system the car wont open the boot without having the key
u try on your car....don use your wireless key go to open your car but the small little key....plug into the hole of e car..... next u put the key like 10m away from your car and try to open the car boot.
I really cannot understand... If u can open ur door... why can't u open the boot with the latch that is below the driver side door handle... that one is a mechanism.... no sensor needed... or u dunno where is it? And fyi... if ur key is in the car.... even the boot... car is not supposed to lock by itself....
 the safety mechanism if the keys are left in the car is only for cars with keyless Go.
<p>zaino-logo-1.jpgZAINO AUTHORIZED DETAILING CENTER 176 Sin Ming Dr, #04-08 Sin Ming AutoCare, Singapore 575721TEL: 67449119 / 97167788ACELLENT AUTO INSURANCETEL: 67449119" We Treat Your Car Like Our Own!"https://www.facebook...cellentgrooming
I wonder did the locksmith triggered my anti theft system.....if he did no matter what we tried it wont open
