Oil change capacity & method of oil change for C180 1.6CGI
Hi All
I am new and have 2 questions to ask for 2012 new C180
1.) Anyone knows for draining of oil, do they suck out the oil with suction or drain it from the drain plug below ? I read from internet but some said it is from suction pipe from top (the place where we pour in the oil ) some said drain from the plug below the oil sump.
2.) How many litres of engine oil is required?
Also anyone has this issue ( not sure if its an issue ), drive to some where quiet, off the air-con so that the cabin is quiet, turn the steering, left or right, do u hear some "grinding" sound from the steering wheel ? sound like the "teeth" of 2 gears running pass eachother but not exactly in a smooth way. very very soft sound like "grek grek grek" otherwise everything is fine and turns ok
