Reset message after brake pad change
Watisthis1
  • Replies 4
bro, usually when you send ride fr yr basic or std servicing, yr SA will hve a report indicating tat yr brake pad life span! :beerhat:
Anything fall below 20% the sencer will melted, thus your warning msg will light up! :D
You ve to get it replace otherwise, there s no way to clear msg off just fm your cluster! :hocky:
By per pc fr frt and back! :rock:
There are sensors for the front and back. When you change your brake pads, did you replace these sensors too?
I've just changed all my brake pads and disc and sensors, after the "Check Brake Wear" comes up.
Been driving for 3 days already, and message stops appearing.
Btw, these ATE pads are really "dust free" man!!! Shiok.
