ABS & ESP Inoperative, Run-flat Inoperative
Guest schnitzer7
Guest schnitzer7
hi bros, need advice ...
anyone encounter "ABS & ESP Inoperative, Run-flat Inoperative" message on the speedo?
Ran the diagnostic and found it to be speed signal (sensor) fault ..
Mech said need to check for the parts replacement, is it safe to drive when ABS & ESP inoperative??
My car is from PI, warranty just over, can recommend good Merc workshops to carry out checks and servicing? Since warranty over, should I go for TWM warranty??
Pls advise .. thanks, Cheers!!
TWM!! Do a search here & please read up. Look for our starkblack or MBM for advise. Is dangerous to drive without ESP & ABS, go real slow if u need the car.
Guest hkhamateur
Bro Schnizter, firstly a big :peace: :welcome:
yes, bro blackmercs was correct abt e importance of these ABS/ESP feature. :shocked:
Imagine u drove w a slick tires on a sandy road! Can u ctrl yr ride when on bends, cornerg n stoppg? :whistle:
Urgently get it done. U can visit our site-sponsors: Starblack n MBM. :hand:
They were equally gd as C&C in term of technically skills/ knowledge n technology. :thumb:
Guest schnitzer7
thanks for your advice, bros .. will visit either MBM or starblack for 2nd round of checks.. now have to drive slow to get to their workshop.
it all happened after i collected my car from the valet, went back to ask him what did he do, he denied anything ... wonder is just bad luck / coincidence?? :(
hope nothing major ..
Cheers!
Guest silverarrow
One of the main reasons why I don't let valets park my car unless really boh bian...
Cheers!
Guest hkhamateur
Cheers!
Ya...true, I never let valets handle my ride! :whistle:
Mayb our Mercs re footbrake so he didn't knw how to unlock as its diff fm conventional type. Then whack e acceler thus burnt e sensors! Possi right! :shocked:
Few months back also got this issue.. turns out is a brake light switch that is faulty.. You can also try to operate cruise control and speed limiter, and it does not work too for my case.
That is after I change my tyres. Anyway.. paid $140+ for C&C to fix. mine is a W211 E200K.. '08.
Guest schnitzer7
had it checked with MBM and another Merc specialised workshop, it's confirmed that it's the speed signal sensor (front-left) faulty .. said it's common problem in almost all Mercs
problem is .. MBM said need to change all four sensors when the latter workshop said only required to change the faulty one.
What do you guys think? pls advise .. thanks
Guest hkhamateur
Wa....like wat bro arshavin quoted, if its under warranty go C&C fr a geniune claim. :becky:
Otherwise tat particular sensor shld be replace unless you wanna peace of mind than change both frt two sensors lor! :whistle:
If nt go Starblack just to change the faulty frt left sensor if MBM insist tat 4 sensors needed to be replace which u re nt comfortable la! :hand:
Guest schnitzer7
out of warranty bro, that's why heed your advice to send in to MBM for a check .. and it's PI car .. *dilemna* ..
