Tyre Rotation
Guest Red Devil
Guest Red Devil
Just wanna check for tyre rotation need to update the car system ? I am thinking of doing rotation outside, and my W204 has the tyre pressure monitor. Wonder will system show any message after rotation.
Any advice to this noob qn ?
Thanks in advance.
Red Devil wrote:
Thanks in advance.
Just want to confirm with you again!
U have
Tyre Pressure Loss Warning System or
Tyre Pressure Monitor System?
The former do not have sensor in your wheel while the later has?
If it's the later, U likely have to reset your TPMS.
If it's the former, just ensure the tyre pressure are kept to the specs.
U have
sifu, which Mercs model comes with sensors in the wheel.
IMHO! I m no sifu!!!!
It's an option for some MB models as informed by CnC.
If U are interested in Tyre Pressure Monitor System & not Tyre Pressure Loss Warning System - U might want to contact them!
Dear Mr. Seah
Thank you for your enquiry via our Mercedes-Benz website on 12 May 2011.
With regard to your query, kindly be informed the Tyre Pressure
Monitoring System is an optional item. With reference to your vehicle
sales agreement, we noted that you did not opt for this system. As such,
your vehicle was not delivered with the Tyre Pressure Monitoring system.
Please be informed that your vehicle does comes with the Tyre Pressure
Warning System, which is a standard feature of the vehicle. For this
system, the sensor would reference the wheel with one another and when
one is different from the other, the instrument cluster would prompt the
driver that there is a flat tyre.
With reference to the Tyre Pressure Warning System, it is not required
to purchase any sensors when the rims were changed.
We hope that we have answered to your queries accordingly and wishes you
an enjoyable weekend.
Yours Sincerely,
CYCLE & CARRIAGE INDUSTRIES PTE LTD
Customer Relations
Customer Assistance Centre
Beru TPMS sensor fitted on some olders MBs
TPMS can be direct using wheel sensors or can be indirect using the ABS & ESP sensors!
Wiki has everything :lol:
http://en.wikipedia.org/wiki/Tire-pressure_monitoring_system
Some links for your reading pleasure! :becky:
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=44#sensors
http://www.benzworld.org/forums/w164-m-class/1299218-tire-pressure-monitoring-system-my07-ml350.html
http://mercedesforum.com/forum/mercedes-sl-class-15/tpms-sensor-problem-41246/
Dear Mr. Seah
Yours Sincerely,
Customer Relations
Asoka, I m not Mercs owner liao, so can u ask them whether they hv karaoke system for the new C coupe.
Kum sia
Kum sia
Mai OT lah!!!! :lol:
TPMS can be direct - using sensors on wheels on indirect working usually on the ABS & ESP sensors!
OEM TPMS sensors from VDO on eBay and the list of suitable cars!
http://cgi.ebay.com/ebaymotors/TPMS-TIRE-PRESSURE-SENSOR-MERCEDES-SL65-AMG-SL600-SL500-_W0QQcmdZViewItemQQhashZitem256351cdb9QQitemZ160580095417QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Here's a whole list of MB TMPS sensors available for eBay!
http://shop.ebay.com.sg/i.html?_kw=mercedes&_kw=tpms
Beru TMPS sensors on older MB car
Original MB TPMS sensors for 2010 and 2011 Mercedes-Benz AMG SL
Some threads about tmps on other MB forums for your reading pleasure!
http://www.mbworld.org/forums/gl-class-x164/156466-tire-pressure-monitoring-system.html
Guest Red Devil
U have
errr .. I guess if tyre pressure losing, it will show message in monitor. confused :(
Most of our MB car comes with Tyre Pressre Lost Warning System - meaning there's no sensor in the rim.
In the event of a tyre puncture, the different in car tyre pressure with the rest of the tyres - there will be a warning message!
So if U are rotating tyres, just make sure the tyres are correctly inflated.
Guest lightning
yes, i have encountered that before in my W212...the red warning message came on to ask you to check your tyre pressure...you need to reset after you have patched the tyre.
Guest Red Devil
Many thanks.
Guest mushigen
When you have an under inflated tyre, the outer circumference will be smaller and the wheel will be rotating a little faster than the rest. Imagine using a spare 15" tyre with the remaining 17" tyres and you can see that the spare tyre will rotate faster than the rest. The ABS/ESP sensor will detect this wheel rotating faster and give the driver a warning.
Guest carnipotent
Sometimes the TPLWS does not work even when you have a punctured tyre as was my case. I sent my car for tyre rotation and they found a nail embedded. When they pulled out the nail, air gushed out. Perhaps not too much air was lost when it was punctured. But on another occasion, it worked like a charm.:clap2:
