Roof water leakage
Hi bros, my ride has leakage problem.. went to CC and they change the entire rubber roofing for me... now this problem recur again.. tmd... going down to CC again.. is this a common issue you guys experienced as well ??
  • Replies 12
  • 3 months later...
Finally an update on this...
Got C&C to sort out this issue.. took a while because they need some time to get me a replacement car... i make some noise because the leakage has been persistent despite them checking on it twice.. C&C got me a E250 Sedan as replacement... quite a comfy ride..
back to the issue of leakage, initially thought it was the rubber seal that is the root of the problem. Turns out it wasn't.. hmm... C&C insists that there is no leakage until they see the video i recorded.. eventually the car was in the workshop for nearly 3 weeks.. couple of days back C&C called to say they are changing the entire roof of my ride.. collect the car today. The entire roof is replaced: my stock is the metallic roof but they change it to the glass roof for me !!! Will need to check during rainy day if the leakage recurs but C&C reassures me that with the change of the roof the issue is resolved.. tested the roof: opening and closing no problem.
Happily drove home.. parked car... open car boot.. FUCK !!!
The opening of the car boot is usually very smooth.. today it feels like the car boot is like super stiff.. i actually need to use strength to open it...call C&C again: told that it is supposed to be stiff.. however previously it wasn't this stiff ie.. i actually need to use strength,, like machiam doing bicep curls ?!
Noticed also the left side of the rubber seal at the boot was misaligned... !(#!_#)!#@$&@!
Send the pics via whatsapp to the C&C staff..
shall see what's the issue... Haiz.....
Check with you bros, does your SLK car boot opening really stiff ?
Wow! C&C can retrofit pano roof? I'll be calling them up to enquire!
Not really full pano roof.. my stock is the metallic one... so they change it to glass partially.. from outside it looks like pano roof.. from inside car the plastic/metallic roof is there.. no sunshine can penetrate in if you get what i mean.
It does look funny from the top.... but as long as it solves the problem...
LLST..... Can only go back CNC and KPKB...... If they cannot help u..... Guess no one else can..... Cos this is hardware issues.... Btw how long is your ride?
ride is coming to 3 years old..
