B180 W245: Steering wheel squeak
Denz
HI I have a yr 2010 B180, W245. Recently the steering wheel squeaked while turning at low speed. It sounded like 2 pcs of rubber rubbing against each other.
Brought it to the work shop, they overhaul the steering rack & change a new steering coupling, but the noise persisted. I was then asked to change struct mount and again didn't solve the problem. Anyone has similar experience? Where is the fault? Please recommend the workshop that solved the problem.  Thanks.
