Monster-Tune.com
Monster Tune Workshop
92 posts in this topic
Intercooler Upgrade for improved turbo-charged air cooling efficiency.
Before:
42E7E6A8-697F-4671-8BBD-D068B69D8F99_zps
After:
4F7A3417-E59D-4ED8-9A4F-B71C70D087E4_zps
Share this post
Link to post
Mercedes C63: Wheel Speed Sensor Replacement + Factory TPMS Replacement + ECU & Transmission Remap.
84FC3340-F4A8-4049-8970-995B36C68EBE_zps
Share this post
Link to post
Introducing Interstar PowerPedal - A simple, Bluetooth-enabled Plug-N-Play device that changes the way your pedal interacts with your car’s acceleration mode. These acceleration modes greatly improve the driving dynamics of your car by improving acceleration response and removing any dreaded turbo lag. All these while safely protecting your car’s electronic throttle modules (electronic injection, ABS, etc.).
3 Acceleration modes :
     • Dynamic mode - Improved response up to 25%.
     • Sport mode - Improved response up to 50%.
     • Race mode - Improved response up to 75%.
82756444-B1EC-4F9E-982B-28EA5F02FA4A_zps
B4C55867-6971-44B8-BB61-262026C1C551_zps
7A8E04E4-4184-4CD9-BE3B-E378A64C5416_zps
9DB0D879-3C01-48C9-8B6E-0FB7C1F39139_zps
Share this post
Link to post
BMW 116D Wagner Intercooler Installed. On of the lightest and most efficient Intercoolers available.
3B63956A-5C96-4AA6-8090-C6A483DE3B62_zps
2B952838-16C1-4C9B-AC32-FCC6C4294887_zps
B959ACA2-13D7-45D8-9E8E-AECABAC08829_zps
Share this post
Link to post
Audi TT Mk3 8S Monster Tuned
454HP & 601NM at the crank est.
1) TTE470 Hybrid Turbocharger
2) MST Performance Intake System
3) MST Performance Turbo Muffler Delete
3) Forge Motorsport Diverter Valve
4) Forge Motorsport Intercooler
7C5CD72C-868D-4118-9EF6-2A92F6E2EBF0_zps
88160749-60B1-430F-9720-6D035FF78536_zps
6326104C-4B02-40E1-8DB1-5BA804910EB0_zps
#tte #theturboengineers #mstperformance #audi #ttmk3 #mqb #monstertune
Share this post
Link to post
Mercedes C180 getting ready for a major overhaul.
5E587ACC-7110-4D79-A698-467B5DEB3CE8_zps
Share this post
Link to post
Mercedes C180 came by for a full overhaul because of worn piston rings due to high mileage usage.
Monster Tune isn’t just a regular battery replacement, aircon testing, brake pad replacement or routine servicing garage. We do way more. Do drop by should you require any heavy lifting to be done.
17ACD708-B46C-4BCB-B108-894E5F77379E_zps
All done and clean!
BB70ABA3-FA6B-4216-B267-D28075BEAC47_zps
C970BFA9-7B1B-47FB-83F7-B3FBC28C2C7D_zps
Valves grinded and looking like new again.
DAA0F4B5-09DC-4FD0-A3F3-D9763E292D81_zps
#mercedes #c180 #c200 #e200 #e250 #overhaul #monstertune
Share this post
Link to post
Mercedes E250 alternator replacement
7DA2E6E3-2AFF-4962-A398-03B9F3A70180_zps
Share this post
Link to post
Mercedes C180 came by for an overall health check due to its high mileage. One of the key components amongst others is having the car’s injectors checked and cleaned. There are no real viable ways to do this until the arrival of our GDI injector cleaning machine. It’s the first machine in Singapore that is able to accurately diagnose the health and clean injectors for direct injection engines.
8CCD20D9-690A-403E-8E8F-4876004966C6_zps
In this case, we can clearly see in the video below that the spray volume from every injector is very much different. With this precious information, we can then take the correct steps to rectify the problem accurately.
#gdi #injectorclean #mercedes #benz #monstertune
1 person likes this
Share this post
Link to post
Customer with the Mercedes 2.0 Turbo engine came in for diagnostics due to power loss issues after some modification works done. Initial suspicion for intake fitment issue was confirmed by a leak test. Poor fitment resulted in a massive leak which affected power and fuel economy.
Share this post
Link to post
Do you know that overfilling of aircon gas can have an adverse effect and it shortens the lifespan of your car’s aircon system? Do you know that your car’s aircon system requires frequent servicing just like its engine?
Introducing the Kooltec AC Flushing System:
Kooltec is an AC 'tuning' system that replaces gas and lubricants at optimal levels to achieve peak performance.
• Reduce damage to cooling coil, compressor and condensor
• Removes fungus, toxin & bacteria build up
• Recommended for every 40,000km or 2 years
12FC5F52-BB24-4986-ADB3-861DF9ABDEAF_zps
Share this post
Link to post
Mercedes A180: Forge Motorsport Blow-Off Valve Adapter Installed.
A brief description from Forge Motorsport:
“It has been designed to work with the original electrically controlled solenoid and utilises high quality o-rings for a perfect seal. Mercedes equipped your car from the factory with a recirculating style turbocharger valve which allows the charge air to be routed around the turbocharger from the boost side back to the intake side. The downside to this style of system is it recirculates the hot air back into the intake side of the turbo, increasing temperatures. When equipping a vehicle with a Blow Off Adaptor like ours, it helps remedy this issue. This great solution for open air venting includes everything you will need for the install.”
405A049A-71E3-4DBA-BD54-6FBECB173CB8_zps
8B99F345-2C7F-49DF-84B5-4F1A759792C3_zps
99ECAEF8-490E-4D00-8835-DDE07588D2C9_zps
Share this post
Link to post
Mercedes CLA200: Snow Performance Water-Methanol Injection Kit Installed.
-cools intake charges
-increases fuel octane rating
-detonation prevention
-more power (custom ECU tune required)
C4E7507C-2BE2-4C4C-BA0D-66B49C38DA2C_zps
19764B9D-6B64-408D-B2AD-F913715EE4EC_zps
5EFD1F69-F3E7-4D2C-B215-E621F4777432_zps
Share this post
Link to post
Mercedes ML350: Belt & Bearings replaced.
#mercedes #ml350 #monstertune #carservicing #carrepair #autogarage
9BB43490-FC46-4F8F-900A-CC746E603103_zps
8E0F782C-FD66-481C-BDEE-1B0314219EF1_zps
Share this post
Link to post
Mercedes CLA180: Turbocharger replaced due to a damaged compressor wheel on stock turbocharger. Car was carefully retuned (previously on XXX tune) on our AWD Mustang Dyno with road-load simulation.
+28hp & +32Nm over competitor tune.
58E7DBDC-B22B-4D53-9C6F-18918D1C0ED9_zps
BD7E573C-5F2B-455B-A532-09A2911E45ED_zps
15D5D1CD-FC26-4C2D-80D4-E259C3DB114C_zps
#mercedes #benz #cla180 #cla200 #ecuremap #ecureflash #enginetuning #monstertune #monstertunehk
Share this post
Link to post
2B82581D-EA1A-4E60-926A-1D353B5E21F4_zps
All our cars are tuned on our Mustang Dyno with road load simulation. Extremely accurate with no-nonsense-no over-inflated results. NO touch-ups nor updates required.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
