Custom Fit Sunshades from Groovy are here!!! Made in Taiwan.
http://i4.photobucke...pi/photo1-2.gifSunshade is designed to Fit with your window's shape for each model with Anti UV.
Simply installation using 3M tape attached with holders for installation. No drill required. Just easy step that is Clean and attach
Whole sunshade is located parallel with window glass without disturbing to window slide up/down. No need to take off when want to close/open window
Able to see through sunshade while driving in sunshine
Left of the photo is our Custom Fit Sunshade - OEM Material which is thick and very lasting. Right is those normal cheap thin sunshades old outside.
http://i4.photobucke...pi/1445450f.jpghttp://i4.photobucke...pi/1e79839f.jpgCustom fit Sunshades on VW Golf MK6
http://i4.photobucke.../ocpi/e2001.gifhttp://i4.photobucke.../ocpi/e2002.gifCustom Fit Sun Shades for Merc E200 W211
These are the car models with Custom Fit Sun Shades
Custom Fit Sun Shades for different Car Models. Features:
1) Fit Shape: Sunshade is designed to Fit with your window's shape for each model
2) Anti UV: With the real 100% OEM material used to produce this Sunshade, you can trust in its quality that can protect you as OEM built in sunshade
3) 3M Tape: Simply installation using 3M tape attached with holders for installation. No drill required. Just easy step that is Clean and attach
4) Collapsible: Sunshade are collapsible in compact size when no need to use sunshade. Increase more clear vision while driving same as before installation
5) Transparent Vision: Able to see through sunshade while driving in sunshine
6) Whole sunshade is located parallel with window glass without disturbing to window slide up/down. No need to take off when want to close/open window
If you want to darken your window for your baby at the back seat or just want a dark tint effect without getting fine, now you can with Custom Fit Sun shades. It is not against the law to have sun shades in the car. If any LTA enforcement officers stopped your car, just remove it on the spot and unlike dark solar films, you do not need to tear it out and also it's not very expensive. Plus you can still see the outside from inside the car. VW centre are selling just 2 pieces of the rear sunshades at around $180. Ours are much cheaper plus it comes with 4 pieces. Fully customised for your car windows. Material used for the sunshades are the same oem material used for BMW or Mercedes rear window shades. Not those cheapo type.
Why Custom Fit Sunshades than darker solar film or car curtains?
1. You can take out the sunshades at night if it's blocking your view at night. You cannot take out a solar film on the spot.
2. You are able to see the outside from the interior of your car even with sunshades. You are not able to see anything when the car curtain is there.
3. Inexpensive as compare to solar film. You can have both solar film and our sunshades. Rather than getting a super dark solar film and risk getting caught by TP or LTA.
4. Looks much nicer than those ill fitting sunshades u find outside.
5. Car curtain are not customised, so it does not fit exactly as compare to ours.
6. Children or baby in the back seat will not scream as sunlight shine onto their faces as the sunshades are there. Even solar film will not block all the sunlight.
7. Reduce temperature of your car interior under hot sun.
Special MO price - $140 for Mercedes cars. SUV or MPV other prices. Please sms me at 96952338 with your car model and transfer $20 to POSB Savings 009-31912-3. Add $5 for delivery every Tues or Wed nite islandwide. Try to do order earlier if you still want to get by end July. Thanks. Stocks are here:Civic FD 7Swift 1Jetta MK6 5Golf MK6 5Prius III 09 1Jazz GE 1BMW F10 1City 06 1Wish 06 1Vios 12 1Lancer 06 1City 09 1Accord 08 1
