Anyone done this upgrade on their W204? Very good read!
Guest grey3443
Guest ricric_lo
Hi, if you need the factory document on how to remove/install the door panel, just send your email to me via PM, I'm pleased to provide such document to you.
However, if you knew nothing about the car audio, had better spend a bit more money to leave those thing to the professional in order to avoid damanging your ride.
Cheers, Ricky
Guest grey3443
Thanks in advance! Actually, I have no intendtion to mod the speaker on my own. I'm merely buying the idea of changing the stock speaker to the recommended Infinity speaker for both front and back.
Guest grey3443
Wes23 wrote:
Bro, it would be advisable to check out some others brands too. Some of our bros here have modified their ICE system! Hear them out then decide again!
I know, that's why I'm posting for suggestion. The suggested mod sounds cheap and good....
After market component sets are usually "high-power" and need proper amps to drive them.
By changing the stock speakers to after market component set, you stock amp imho is not "beef" enough to drive them.
My Rp2 worth!
do also note that being component speakers, the crossover points might be different between the stock component speakers and the new speakers. Just because it has the same drive units (tweeters and woofers) does not meant their crossover is at the same frequency.
  • 5 weeks later...
Guest subaru67
My Rp2 worth!
uncle... so min need to add at least an amp if i change aftermarket front com speakers right... if just change speaker maybe not enuff to power them... btw stock w204 is brandless right but funny the bass is shiok as compared to jap cars
Guest grey3443
According to my attached, the writer actually says that the stock head unit actually have a decent power to pump up the speaker. I will try and see if it is true when my ride arrive.
Guest subaru67
oic... hahaha what com u planning to install?
