w207 Shocks Woes
Guest dav1dyeo
Guest dav1dyeo
Hello Brudders
I'm having loads of trouble with my coupe ( w207 ) shocks. I have changed the shock absorbers frigging 3 times at TWM over 6 - 8 months. I heard it's a defective design but the newly designed shocks are not available yet.
I'm thinking just change to a coil over or some other good shocks that gives comfortable ride, really getting sick of driving abouts in a bumpy car. Any suggestions or lobang?
  • Replies 5
dav1dyeo wrote:
Hello Brudders
I'm having loads of trouble with my coupe shocks. I have changed the shock absorbers frigging 3 times at TWM over 6 - 8 months. I heard it's a defective design but the newly designed shocks are not available yet.
I'm thinking just change to a coil over or something, really getting sick of driving abouts in a bumpy car. Any suggestions or lobang?
Yr ride is C207 for a coupe. Yr bumpy ride is when u go over a hump or throughout the ride? Is it kinda too soft feel?
Guest dav1dyeo
The ride is bumpy and hard throughout the ride, a lot of sounds at the front undercarriage over uneven roads. The garage confirmed it's again the shocks giving the trouble.
dav1dyeo wrote:
Hello Brudders
Try KWs. They are known to be compliant and comfy in terms of ride quality.
U hv changed 3 times & the problems still persists!! If u can come to this Friday meetup or our monthly gtg give me a short ride. This is really bad but I m not too sure whether is the aborsber issue. Even you change to a coil over will resolve yr problem or not? But if this is only the solution then get a good set of coil over. Good luck!!
  • 8 years later...
