O2 Sensors
Mike73
I drive the W212 09 model. When the engine check light comes out, the mechanic mentioned that the O2 Sensor is faulty. I found out that they 2 of types. There is this upstream( located before the Cat) downstream( located after the Cat). I have changed the upstream O2 sensor.
Problem still remains. Anyone can advise what to do next. Thank you
Go to a reliable workshop to get a proper diagnostic of your CEL problem
That workshop didn’t diagnose your car properly. Please go to one with the proper licensed Xentry to get your car properly check. I suspect problems are not from your Air flow sensors. Those China OBD always throw out air flow sensors faulty codes. You can go to Trendy Automotives, look for Uncle Tony to settle for you.
