Power steering malfunction
On 6/16/2018 at 11:15 AM, RT6280 said:
Bought a new W205 for 1 month encounter power steering malfunction, C&C took 3 weeks to get it fixed. Disappointed with the quality & service, can I claim loss of usage?
@RT6280 Bro, any early warning or did it just fail without any warning? Thx for sharing.
1 hour ago, RT6280 said:
Without any symptom, steering wheel just locked up and had to towed away, only shown power steering malfunction message. It would be disaster if steering wheel locked on expressway, no confident in Mercedes car
@RT6280 Thx again for sharing. currently in the Q awaiting collection of my W205. This info is definitely not encouraging. Let's see. Cheers.
I suspect is the ESL motor burned out which is very uncommon. I did not work on this car nor I seen the car either from SDS or visual.But I did work on a W204 which had this issue.
It also could be many other factors such as bad power steering pump, leaky reservoir, bad hose or bad belt. I cannot confirm this is the case
I don't think C&C have them in stock thus need to indent. Thus it takes 3 weeks. All cars are bound to failure and new car are more prone to defects due to many factors.
1. The way how it is transported to the factory floor
2. Every item are not inspected visually unlike at the workshop the mechanic will inspect the item and make sure its the correct fit and no damage
3. Damage while in shipment
4. All other factors
