How to start the car engine the correct way?
Hi, I am new to the forum. I saw an FB video that says that for cars with 'Keyless Start', one will have to press the Start-Stop button once (without depressing the brake pedal) to let the ECU do its checks before pressing the button again (now with the brake pedal depressed) to properly start the car. It is said that doing this will prolong the lifespan of the ECU.
I have been starting my car by pressing the Start-Stop button directly (with the brake pedal depressed). Have I been wrong all the while? For your opinion, please. Thank you.
It's correct that you've to step on the brake pedal to start your car with the Start/Stop Button
Thanks for the reply. Yes, it is correct that you are to press on the brake to start the car. But someone said before you do so, you would have to press the Start/ Stop once without stepping on the brake. I don’t know how true this is.
On ‎14‎/‎6‎/‎2018 at 8:04 PM, Prestigious said:
Hi. I tried to find it but was unable to. By the way, it was about a Toyota Vellfire.
My 2017 Toyota New Fortuner also start the same way.
1. Step on Brake Pedal and push Start/Stop button
